1 - 1 of 1 Posts
The 2011 Polaris Trail Boss 330 ATV is the best value mid-size trail/utility ATV. It features Sportsman-like styling, 2-wheel drive and long-travel rear suspension.
Key features are:
•329cc Air/Oil Cooled Engine
•Lock & Ride Racks
•Automatic Transmission
Features:
Drive
The Trail Bloss features two-wheel drive system.
Transmission
Automatic PVT transmission with forward, neutral, and reverse.
Easy Braking
Single-lever braking keeps makes braking simple.
Lock & Ride
Lock & Ride Front and Rear Steel Racks (75 lbs. in front; 125 lbs. in rear)
Engine
4-Stroke Engine (air/oil cooled w/ fan assist)
Suspension
Long travels suspension gives you 10.5" of rear suspension travel
Specifications
MSRP $4,299
Engine
Engine Type 4-Stroke Single Cylinder
Displacement 329cc
Fuel System Carbureted
Cooling Air/Oil with fan assist
Drivetrain
Transmission/Final Drive Automatic PVT F/N/R; Concentric Chain
Drive System 2WD
Engine Braking System/ Active Descent Control Accessory/Not Equipped
Suspension
Front Suspension MacPherson Strut with 8.2" (20.8 cm) Travel
Rear Suspension Progressive-Rate Swingarm with 10.5" (26.7 cm) Travel
Brakes
Front/Rear Brakes Single Lever 4-Wheel Hydraulic Disc with Hydraulic Rear Foot Brake
Parking Brake Lockable Hand Lever
Tires Wheels
Front Tires / Model 23 x 8-12; 489
Rear Tires / Model 22 x 11-10; 489
Wheels Stamped Steel
Dimensions
Wheelbase 48.5" (122 cm)
Dry Weight 531 lb (239 kg)
Overall Vehicle Size (LxWxH) 75 x 45 x 49" (190.5 x 114.3 x 124.5 cm)
Ground Clearance 4.75" (12.1 cm)
Seat Height 35" (89 cm)
Capacities
Fuel Capacity 4 gal (15 L)
Front/Rear Rack Capacity 75 lb/125 lb (34 kg/56.7 kg)
Hitch Towing Rating 850 lb (385.6 kg)
Unbraked Trailer Towing Capacity "*Based on EU Directive 76/432/EC 1,263 lb (572.9 kg)
Hitch/Type Standard/Drawbar
Features
Cargo System Lock & Ride
Lighting Dual Hi/Low Beam (30w/30w) Headlights; Single Rear Brakelight/Taillight
Instrumentation N/R Light, Fuel Gauge, Hi-Temp Light
1 - 1 of 1 Posts
