Can some one tell me why my 2011 sportsman 500 drowns out so easy as soon as the pipe goes under water and how can I fix this still new to Polaris never had that problem with my old foreman.
Your in the right path the steam ends up going in the vent tube and kills the bikes. Seen it a ton.^^^^agreed ^^^
Its his ride to do what he likes.
Its possible the carb vacuum line may be going under and killing it.
Sent from my MB886 using Tapatalk 2
Guess my buddies 2012 500 on 29.5 laws that pretty much goes through anything you can throw at it should stay on dry land.Yes I do apologize for my past post.Yes I am a bit harsh at times.However, he has a 2011 500 and he wants to take it swimming?Come on, smell the coffee.This machine was made to be driven on dry land, not up to the handle bars in muddy water.I would check around the spark plug as water may be shorting it out.Hope this helps in some way, Ken
If you don't like using your atv to its full potential then don't. No need to make comments like this. All my atv's go up to 6 feet deep from the day they are new with no issues. Set it up properly and do basic maintenance and it will have a problem free life.Next time you get the urge take a life preserver.Buy a kayak or a canoe.Their is a reason the machine has tires on it.Stupid...
6'? that seems a bit far fetched... your snorkles must be insane.If you don't like using your atv to its full potential then don't. No need to make comments like this. All my atv's go up to 6 feet deep from the day they are new with no issues. Set it up properly and do basic maintenance and it will have a problem free life.Next time you get the urge take a life preserver.Buy a kayak or a canoe.Their is a reason the machine has tires on it.Stupid...
Those are sweet! Got $40,000 though?
