Hi all,
Need some guidance on where to start. Mid-ride I noticed the headlights quit with no other symptoms for the rest of the ride or during a couple since. Finally got some time to look at it, figured out the 15A fuse labeled "EFI" was essentially melted. Bike has a carb so assuming the fuse block is used in several other models? Regardless, replacing the fuse with a good one means no power, no start. Key essentially does nothing. However, it continues to start and run fine with the fuse pulled?
I've searched looking for other posts with a similar problem and a fix, can't find one. Looking for some advice on where to start looking and what to do first?
Also, I don't have a service manual but would love to get one to have if someone can point me where to buy/download.
Thanks!
Thanks!
