I have a 2011 polaris sportsman 500 h.o. Evething lights up speedo and lights. When i turn the key to start it nothing happens no sound nothing. I checked the fuses and they are all good..Any ideas on what to check ?
You need to flip your positive and negative wires from the battery. If its not that i dont know what it is.
If that were the case then his speedo would not activate. It sounds like it worked one day and then just didn't start on another day. He didn't mention any recent repairs.
Aside from a ground issue, it could be a host of things such as the starter solenoid, starter, fuse, loose wiring, etc. just need to start with the simple things and work backwards from the starter. A volt meter will prove necessary.
