I have a 2011 sportsman 550 and I'm trying to decide on which lift to get. I already have rhino axles all the way around the bike. The high lifter signature series 3 inch lift is like $499 but requires new axle bars or gorilla axles. The catvos 3" 2.5" extended lift is $599 but the guy said that my stock length rhino axles would work fine what do you guys think
I think catvos is bullshitting you, since Rhino axles will not hold up in the long run with ANY lift. Rhinos are only really good for large tires without a lift. They don't take the angles very well.
Gorillas or turners are your only real option if you intend on lifting.
Thanks for the input but, my question wasn't if the axles would hold. I was asking if stock length axles were right, but mostly which lift to go with, also I found the slc 3" 2.5 raked lift too it seems to be what and what with the catvos lift , besides from what I've seen on these forums and others gorillas aren't what they used to be either, I like my rhinos, once I lift it and they break I'll replace them with something else like gorillas, cobras, or turners
Welcome to the board!
