i have a 2012 550 rad relocate snorkle 27 mega mayhems about to either go to 28's or 30's with a 2in lift. what kind of clutch do i need to get.. used in mostly mud. also what kind of difference will i notice power wise on takeoff? also should i use another stock belt or a aftermarket belt?
I would call qsc for a kit they will fix u up. On the belt everything I read says go oem Bc some people have problems out of aftermarket ones. As for noticeable with a kit yea it makes one hell of a difference!!
2013 850ho
I would think both but if u call qsc then they will ask u questions and help u with what u need. It will be put together for ur bike not just a off the a shelf kit.
2013 850ho
does qsc do both because i have seen people that do qsc primary and stm secondary. anybody specific i need to talk 2? and is a 2 inch lift good or should i go with a 3 or 4?
U can run 30" tires without a lift. If u run a lift ur gonna need new axles. I think qsc can help u more then I can.
2013 850ho
