1 - 11 of 11 Posts
· Premium Member
Font Line Window Pattern Screenshot
tot he forum
Ball Gas Font Vehicle registration plate Automotive lighting
· Registered
Discussion Starter · #4 ·
Thank you very much however i am in need of the complete wiring diagram for the fuel pump. I am not getting power to the relay. The relays and the fuses are good so i have a wiring problem some where.
· Registered
Discussion Starter · #6 ·
That is correct. its a 500 efi 4x4 non crew. Ive got power on 3 out of 4 legs of the fuel pump relay. Something is not energizing that particular circuit. If i apply 12v to that circuit manually the fuel pump comes on. Not sure what it is controlled by. It was running great. I shut it off then it wouldnt re start.
· Administrator
Product Rectangle Font Line Material property
I'm not sure what you are doing, but with the relay out, there should only be power on 2 pins of the fuel pump relay. Pins A6 and B6
Schematic Font Parallel Rectangle Pattern
When the relay closes power on pin A6 is connected to pin B7 which energizes the fuel pump.
There is also 12v on pin B6 - when the ECU connects pin A7 to ground, then the relay closes.
If the relay is not activating and there is 12 vo on pins A6 and B6, then the ECU is at fault.
· Administrator
If you jumper A6 to B7 the fuel pump should run - if the relay is not being turned on by the ECU, then the ECU is faulty, needs reprogrammed or there is a faulty connection somewhere.
Take it to a dealer to find out and get it fixed.
· Registered
Discussion Starter · #11 ·
Thank you for your help. The ECM is powering A7 instead of grounding. Going to have to call the dealer and set my wallet on fire.
1 - 11 of 11 Posts
