I don't think there is more than one gear other than L and r. how fast are you going at 5000?Ridinagain,
When im in high gear and run it up to 10mph the rpm is aroud 4500 and it wont shift into the next gear.
Im with you Ridin. It sounds normal to me unless he cant get up to speed.There is no second gear. The rpms will stay pretty steady at a given throttle position as it gains speed. Just like a snowmobile. You may not have a problem at all. Did it just start doing something different than normal or is this your first atv with a cvt clutch system on it?
Yep, Jeff, you need to start your own thread if you want to get responses.2012 sportsman 500
has no power i turn the key and get nothing i thought maybe the shifter position relay.. any comments
