My sportsman is blowing a 20 amp fuse whenever I switch into 4WD. It doesn't matter wet or dry it blows. Does anyone have any ideas? What would be the most likely culprit?
disconnect the front diff electrical connector and throw the switch. if it blows then you know you have a wire harness issue. if it doesn't you know the issue is with the diff.
try a 30 amp...then 40....then 50....you'll find it eventually........
HAHAHAHAHAHAHAHHAAHHAHA
Sorry, couldn't help it.......
