Greetings,
Are these units delivered with pre-wiring for a front winch? I noticed on the unit I just bought there is a red wire on the right side near the grille with a terminal end on it.
TIA
Yes they are
Greetings,
TIA
Should also be a black wire with a terminal end also. Remember, that red wire is not hooked up so whenever you install the winch there is a red wire back near the battery hanging free, and it has to be attached to the battery or the battery side of the solenoid to make the winch work. The ground is already hooked up. These two wires do not go to the winch, but to the winch contactor and a blue and yellow wire will go from the contactor to the actual winch
