What do I need to check or look at on my new ATV? Gonna check all fluids and grease it. Any other suggestions? Then I can install all of my accessories.
Sent from my XT901 using Tapatalk
I think beyond the greasing and checking the fluids there's not much else to do.. I would however go around and check every nut and bolt you can get a socket on.. You never know if something that the dealer was supposed to tighten up during set up was missed..
Good idea to get a couple of spare plug's in case the original's foul out...also good to have a 14mm deep plug socket too.
spark plug wrench is in the tool kit. The NGK plugs are ILZKAR7A10
Discussion Starter · #7 ·
I finally got to ride this beast today, eps is amazing and clutching is a lot smoother on take off. I opened the ATV up some and I can really hear the air intake on this 850.
