They will work just fine. Your tires will stick out in the front wider than the rears so you may not like the look. I used those same spacers when I first mounted a set of mayhems to my stock rims but then i went with new rims and the outlaw tires as i did not like the mud ability of the mayhem. If you do not want to use the spacer you can also flip your tie rod end to gain the needed room for the wider tires.
Agreed^^^. those spacers will work just fine.
I ran the Tusk spacers on my old Honda with no problems. Got them from rockymountainmc.com
I'd rather go with wider offset rims than spacers. Just my $.02
:dito: When I was looking a few months ago. New rims was close to the same price as spacers.
