I assume the 2013 XP 850 is the same. What back spacing are you guys running. The wheels from Polaris ar 4.0 +3 but I read others were using 6.0 +1. I plan on running 27.5 Growlers wiht out a lift kit.
Unfortunately if you go with 27.5 Growlers I am pretty sure you cannot go with 6+1 offest. You will have to stick with 4+3 or your tires will rub.
Phil
