I hope someone can assist me. My 2013 Sportsman 400 is a great machine and I give it near perfect maintenance except,In my owners manual on page 67 says, "Front prop Shaft Yoke" grease fittings 3 pumps max every 500 miles.OK butt, their is no grease fitting anywhere on this shaft.Only thing is a set screw in the front.Do I just forget it? I would like to be able to grease these u joints if at all possible. Thanks, Ken
2007 500x2 le
the slip yoke is located on rear most part of that drive shaft right by the brake pedal mount kind of a pita to get at but there is a grease fitting for the splines not the u joint itself i grease mine every few rides
Discussion Starter · #3 · (Edited)
Shane, yes I have this one.From my owners manual it says front prop shaft but this has to be a misprint. Anyway I pulled the foot rest cover and lubed it the easy way. Thanks, Ken
