I've been reading a lot on here and other places about quads not running on their own and all of that. I'm kinda at a loss. I live in North Dakota and the one thing that i need to work does not work like it should.
When i get it started it shows around 12.3 ish for charging on the diag screen. And thats at around 1200+ rpm. i know its charging but the moment you turn it off and try to start it again it the relay going to the starter just clicks untill i boost it. Cold battery i understand will make it hard to start. But running for over 30 mins doing some very light plowing i come to a stop and it dies then i have to jump it again.
When i bought this quad we had the dealer put a winch and plow set up on it. Worked great last winter with one hang up. Every time i would pull the winch in it would make all my electrical drain (ie dash resetting like you just turned the key on), now it will actually kill the battery and shut the quad off. I've seen something about voltage regulator being "dirty" or "bad" but i'm not sure where it is at on the new model's. Also when pulling the winch in and killing the quad outright it would actually backfire. So that kinda leads me to believe that its running really really rich.
Any thoughts? Hope anyone will understand how i explained. I'm just getting annoyed by this thing.
