1 - 2 of 2 Posts
Hello yall. I have a 13 850 making some bearing noise from what seams to be the rear pinion area. I recently acquired the machine and went threw all the fluids replacing with amsoil. At about 15mph and higher I get a growling noise from rear diff under acceleration that disappears when I release throttle. Should I get that amsoil otta there or is it to late? Or maybe I'm being crazy but its loud and doesn't seam right. No play in driveshaft or any leaks.
Same issue here with my 13 850xp and haven't been able to find a cure. Don't think any fluid will make a difference as it appears to be improper gear lash from the factory. Lots of threads on this but nobody has posted a fix as far as I could find. If you do please let me know!
1 - 2 of 2 Posts
