1 - 11 of 11 Posts
Whenever I let off the throttle when going around 20 mph or higher, my engine will bog down and the check engine light comes on.....been to the dealer three times already..... anyone with the same problem?
No can't say that I have had this problem. Good luck in correcting this problem though.
Have you adjusted the throttle free play/ETC?
Does the check engine light stay on? Does it run well the rest of time and only give you problems when you left off the throttle?
I'm guessing that it doesn't throw any codes bec the dealer should have looked into them if so.
Has the throttle free play been properly set? I am guessing yes.
Bad efi pump grounds have been causing issues on the newer models too.
1 - 11 of 11 Posts
