When I get in water with my atv it tries to shut off with me but as soon as I get out of the water and let is sit for a second it runs just fine. It will also do the same when I go up a very steep embankment and try to hammer on it to make it up it too. What could be happening.
Sounds like maybe you are not getting fuel through the main jet when the throttle is opened above 3/4 of the full opening?
Try draining the carb to see how much water has collected in the float bowl.
May be electrical!!! Especially since you say it happens after you go through h2o. Then again it could be two separate issues!!!
