2014 Polaris Sportsman 570
Hey guys, new to the forum.
After catching my rear rim on a stump, I've got some negative camber in the wheel.
After preliminary inspection, nothing is bent that I can see. When I jack the rear of the machine up, the rear tire hangs vertical, once I let it down, the camber re-appears.
What do you think I need to do in order to correct this? Is there a camber adjustment on the rear tires?
Any info is appreciated!!
Do a wheel bearing/bushing inspection to make sure those parts aren't worn.
