As many others also have experienced with the Sportsman 570, I noticed a leak on the front differential. checked this more closely and also noticed that it was possible to lift the pinion, as if it was bad bearing. Took out the diff and checked bearings and seals. looks good. But, there is a sleeve bushing on the end of the pinon into the gearbox. This is a bit loos on to the shaft. Has anyone managed to find a solution for this? without having to buy a new gearbox. Polaris does not offer this bushing, but shows it on the drawing of the differential
Have searched google up and down but can not find any direct link to where I can buy ..
Not sure if this can possibly be used.
www.skf.com
or
www.skf.com
SKF
or
SKF
