2015 Polaris Sportsman - Never Changed Oil
1448 Views 11 Replies 4 Participants Last post by  yooper265
Hi,
I bought my ATV brand new in March 2015. The oil has never been changed and I'm looking for other's opinions on how bad that might be. It only has 75 miles on it and is mostly used for plowing my driveway and some yard work.
I know this sounds terrible but I haven't been able to take it to get serviced since I no longer have a way to transport it. I do have someone who can come to the house and change it but not before the first snowfall this Thursday.
Can I cause damage if I still used it before the oil is changed? I'll appreciate any advice on this!
Thanks,
Nina
1 - 12 of 12 Posts
I would suggest changing it A.S.A.P! & go by how many hours are on the machine, not miles.
If you're going to use it again before the oil is changed, make sure the oil level is full.
Unlikely you damaged it but I would change it asap . No need to go to dealer for a oil change , it's a easy job at home . lots of youtube videos if you aren't sure how to do it .
Great minds think alike - and at the same time ! :grin
Reactions: 2
thank you both! I'll make sure it's leveled off. one more question if you don't mind... have you found that a polaris dealer is the only way to purchase the parts? (sorry if these are stupid questions... I'm a beginner and it's overwhelming when I don't know even the simple questions.)
If you're referring to an oil change kit, you can find them on Ebay, Amazon, and many other websites.
Go to any auto parts store , they have the oil filter you need and also Mobil 1 - 5w-50 oil , I run this in my 2014 Ranger 570 with no problems .
I was hoping to pick it up somewhere so I can get it faster but I think online will be the best way to go. Thanks a bunch for your help! Much appreciated!
As mentioned, you don't have to use Polaris oil & filter. You can find an oil filter & oil at a local auto parts store or even Walmart, just stick with synthetic oil.
Thanks for pointing out your reply. I didn't see it before my last reply. I'll give that a go first! Tx!
Synthetic oil I hardly doubt you will or did any damage. Everything is so tight to specs now not like the old days where on the first change you had a pile of metal scrape flow out. Oil doesn’t break down from sitting. My first change on my new F150 says 100k. The oil change places still say 3k $$$
I think you mean 10 K :smile
Reactions: 1
1 - 12 of 12 Posts
