Going to have to pull the tranny and open it up. You lost something internally!!!
Does it indicate it’s in high in the cluster? On the rear passenger side take off the linkage from the trans. Manually shift it and see if you can get high to engage.
What's the odds it might be a linkage adjustment issue?
You could hope!!! But if you have every other gear then something's broke inside!!!!
It could be the linkage isn’t going all the way into high since high is the first gear and farthest gear along with park.
