I have a 570X2 with 350 Miles. Was out riding in the snow the other day and all of a sudden there is no power. RPM's go up but no power to wheels, then its back to normal and now back to no power. I am from minnesota thought something froze up so had it in heated garage and still same issue. Any thoughts ?
Check the belt housing for water.
Not necessarily. Pull the red plug on the outside bottom of the clutch housing. If there is no water present I would suspect a glazed or broken belt. To verify that you would need to pull the clutch cover.
