So I was having a problem with intermittent poor running/backfire.
I had replaced the battery the year before, and it never seemed right. So thinking I was getting a low voltage issue, I bought another new battery. No change.
So I pulled the sparkplug, it looked pretty black - so I replaced it. No change.
After reading a bunch of posts about low hour bad fuel pumps, I decided maybe its time to check it out. Took a bit to pull all the plastics to get to the tank. Easy to check the pressure, it was showing 48 psi. I had a factory service manual - thanks latebird - and it showed 58 psi as required.
Ebay had a pump that was made in Japan and came with a lifetime warranty. Replaced it today - verified I now had 58 psi, reassembled and that totally cleared up the problem. Machine only had about 70 hours on it.. Old pump was a Bosch made in China.
Here is the pump I used. Doesn't come with the regulator, but has a lifetime warranty.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
