I hooked up an led bar on my atv but when I finished it I turned it on drove around then it shorted out and now the lights don’t work and it won’t start with a key can anyone tell me how to fix this
Did you wire the Lightbar through a relay ? If not you probably burned either a fuse or some wiring ? Check the fuses first - I believe there are 2 and then check for any burned /melted wires
Ditto chk the fuses!!!!
No fusses are blown but I’ll look for melted wire and I tried to wire it into the wires that lead to the front head lights because it was like that when I got the atv then the top peice fell of so I had to redo the light bar
