1 - 10 of 10 Posts
· Registered
Motor vehicle Automotive tire Hood Light Automotive lighting
Hood Blue Light Motor vehicle Automotive exterior
Hi guys,
I recently purchased a 2016 Polaris sportsman 450. There has been a few issues I’m looking to solve.
Issue 1: About a month into having it, the check engine light popped on and showed code 0 84 which I figured associated to the speedometer that does not work. I replaced the speed sensor based on limited research and it did not solve the light going off or the speedometer working. I ignored it after that.
Issue 2: At month 2, it developed an issue starting (acted like a dead battery and would start with jumper box) I ended up replacing the battery, which didn’t solve it. Decided to go for the starter and solenoid next. Replace the starter and it solved the problem. Althohen I opened up the front panel where the solenoid is located, I noticed this “pulse power plug” that was bypassed. I took the wire out and machine wouldn’t turn over. I can’t find any place where this might plug into.
I’ve included a couple pictures attached that show the wire. It is Red / Orange. I’ve been trying to do research but can’t find anything related to it. Has anyone experienced any of these issues or can shed some light to put me in the right direction? Wondering if there is a correlation between the 2 problems.
Any help is greatly appreciated!
Jordan
· Premium Member
Font Line Window Pattern Screenshot
to the forum
Ball Gas Font Vehicle registration plate Automotive lighting
· Administrator
Are you sure that is a red wire and not a red wire with a brown stripe? I believe that is the connector for the brake light switch - if the brake light is not on, the starter solenoid does not have a ground and it wont start - with the brake light on 24/7, it will drag the battery down while running.
· Registered
Discussion Starter · #4 ·
Thanks so much for reaching out. After further investigation, it seems you’re right. It is a red / brown wire. I guess the question is, where do this plug into? I’m assuming it would go up to the brake lever so maybe something was cut off?
Much appreciated!
Motor vehicle Hood Blue Automotive tire Automotive exterior
· Administrator
The switch is hydraulic and is usually in the junction block where all the brake lines converge. A switch may be available from an auto parts store and the Polaris part number is 4015069 - it is $120 from Polaris
· Registered
Discussion Starter · #6 ·
Can’t thank you enough for your help. That switch is hidden pretty good behind the harness. I
Plugged it back in and it did not work. Are there any other tests that can be done on that switch before I go ahead and order another one? Thanks again.
· Administrator
No other test - it's a NO switch until pressure is applied and then it closes to turn on the brake light - it's either off or on
I've got to replace one on a Chinese Yard Sport - wires are connected with screws - $19
· Registered
Discussion Starter · #8 ·
Thank you, Latebird. I went ahead and ordered the switch. Crossing my fingers that it solves the issue.
Circling back to the light 0 84 2. I read some previous posts that you answered regarding this issue and you suggested to replace the speed sensor. I did this previously and it did not solve the problem. I read your suggestion that it most likely is a defective sensor so I ordered another one just in case this was the problem.
If this doesn’t resolve it, is there anything else you suggest to diagnose? Thanks so much.
Jordan
· Administrator
The speed sensor can be tested
SPEED SENSOR TESTING
Special Tools Required:
ELECTRICAL
Static Timing Light Harness: 2871745
Hall Sensor Probe Harness: 2460761
1. Disconnect the 3 wire harness from the speed
sensor and remove the sensor from the
transmission.
2. Connect the wires from the Static Timing Light
Harness to the sensor 3 pin connector using the Hall
Sensor Probe Harness (PN 2460761 ).
3. Pass a screwdriver back and forth in front of the
sensor tip.
4. Be sure connections are good and 9V battery is in
good condition. If the light flashes, the sensor is
good.
Rectangle Line Font Slope Parallel
SKU Description Qty Retail Ext Retail Notes
KEN2871745 harness, static timing light 128.24 128.24
KEN2460761 harness, hall sensor probe 24.56 24.56
· Registered
Discussion Starter · #10 ·
Can’t thank you enough for your help. Replaced the brake switch this morning and it solved the issue. The check engine light also went off and speedometer is now working. I did not think that they were correlated, but they must have been in some sort of fashion. Thanks again!
1 - 10 of 10 Posts
