Maybe I don't understand but what difference does it make if its in West TN or West Texas? And what difference if it has four seats or two?
I would like to look at one in person if someone has one and would allow me. I’m in TN and West TX would be a pretty long drive. 2 seat vs. 4 seat probably doesn’t make a difference in reality. But I’m dealing with an issue on an XP4, so trying to compare apples to apples as much as possible.
Ok, I gotcha OP You might have to check on a dealership near you if you need to actually lay eyes on one. Or... post up on the RZR forum.
What kind of issue you dealing with. I service and repair a few RZR's and might be able to offer some assistance.
It’s a long story, but that year and model had a recall that required the voltage regulator to be replaced. I need to look at one in person to verify some measurements in the area around the starter solenoid where the wiring harness for the regulator connects.
Yeah, I'm familiar with the RZR reg/rec failures on those machines. Not sure if this helps you but here's a video of the installation of the RMStator regulator relocation kit to get it put up front where it should have been located to start with.
