· Registered
Hello folks. Got a question about a sportsman 110 ignition switch wiring. I bought a non-running 2016 that has had it’s wiring cut to the key switch. From the key switch that’s still attached I can see the four wiring colors red, brown, black and green. The problem is I don’t see where these wires would have plugged in on the wiring harness. I looked at a wiring diagram and based on the diagram that I saw it only looks like two wires go to the key switch which confuses me more. What I think I can tell is one wire is red and the other I think is brown but not sure. Can someone please let me know what the wire connection should look like? Can some one please post a picture? Thank you in advance!
· Registered
There are two wires that I don’t know where they go. A red and brown white. They seem to be the only two wires that aren’t hooked up anywhere. Sorry just lost on what the wiring to key switch should look like.
· Premium Member
Font Line Window Pattern Screenshot
to the forum
Ball Gas Font Vehicle registration plate Automotive lighting
· Administrator
Well, let's determine what you are working on - what is the 17 digit VIN?
