1 - 20 of 148 Posts
NEW! SPORTSMAN 850 HIGH LIFTER EDITION (MUD)
NEW! SPORTSMAN 850 ORANGE MADNESS HIGHLIFTER EDITION
PURPOSE BUILT FOR THE MUD
  • 78 HP ProStar 850 Twin EFI Engine
  • Rack mounted radiator with industry exclusive inverted dual fans
  • Shielded Clutch & Engine Intake Ducting
  • High / super low transmission with mud-specific gearing
  • High mounted vent lines
  • Sealed single beam headlights and sealed key switch
  • Quick Clearing Footwells
  • 4-Wheel hydraulic disc brakes
  • On-Demand True AWD
  • 1500 lbs. (682 kg) towing capacity
  • High flow, high capacity air filter with better dust filtration to protect your engine
  • 50% Stronger front half shafts and 10% stronger front drive for increased durability
  • 29.5" (74.9 cm) HL Outlaw 2 Tires with steel wheels
  • Front Suspension Hi-Clearance Arched Dual A-Arm
  • Rear Suspension Hi Clearance Arched Dual A-Arm, Rolled IRS
  • Fully Articulating Rear Suspension
  • Suspension tuned for mud riding
  • Narrow seat & wide floorboards
NEW! SPORTSMAN XP 1000 HIGH LIFTER EDITION (MUD)
NEW! SPORTSMAN XP 1000 STEALTH BLACK HIGHLIFTER EDITION
PREMIUM FEATURES
  • Electronic Power Steering
  • Industry-first center mounted mud bar
  • Color matched custom front and rear bumpers
  • High mounted 3,500 lb (1587 kg) winch & tow hooks
  • Custom graphics & painted plastics
  • 14" (35.6 cm) custom aluminum wheels
  • 85 HP ProStar 1000 Twin EFI Engine
  • Rack mounted radiator with industryexclusive inverted dual fans
  • Shielded clutch & engine intake ducting
  • Quick clearing footwells
  • High Performance, Close Ratio On- Demand True AWD
Finally some mud ready sportsman from factory, i love that 1000
They are now calling the 850 & 1000 engines "Prostar"?
they always have been.
I like them both, look cool too but why reduced hp in the 1k and less travel numbers?
I'm not a mud machine fan, but I'm glad they finally have an offering to compare to the other brands.
I like the winch switch location and fitment!!!
Banned
Not that I recall. The Ace engine, 570, 900 and 1000 RZR engines are the "Pro Star" family.
Firt time I've heard the 850/1000 ATV engine refered to as PROSTAR........
The 850 and 1000s have been called pro star engines for the past few years.
ATV ProStar Engines - Off-Road Vehicle Engine
I sure hope everything has been beefed up ALOT or there are going to be ALOT of warranty claims!!!
The 850 should have at least come with aluminum wheels, like come on.
2007 500x2 le
I want to know if all the rad relocate/snorkles are available as a kit and how much?
2007 500x2 le
axle on the front are a claimed 50 percent stronger rear are ten percent or something and a super low range for mud usage ...could still be iffy with those big tires on em ! aluminum wheels would be nice but I presume steel keeps price lower
What about the pinion cover?
Called it! They are bad azz and I'm not into going that deep but I like them a lot.
No upgraded pinion!! I have a friend at the Polaris convention and he was sending me pictures. I think this will be the biggest issue we see with the highlifters is front diff carnage. I myself am going to give it some time before I jump on board.
1 - 20 of 148 Posts
