the fuel pump works, i do notice a clicking sound that comes from the throttle body bout 10 sec after trying to start. could use some good advice4
so the starter is rolling the engine over?? pumps running but is it putting out the right psi???
Clicking on the TB sounds like the injector operating - try starting with starting fluid sprayed into the intake - if it starts, it eliminates an ignition problem and it becomes either a fuel or air issue - check the fuel pressure
