Hi I have a 2017 polaris sportsman 570 and the gear i am is not showing up on the gauge cluster just 3 lines are showing up were it supposed to be. If any body has any ideas how to fix it I would really appreciate some help, thanks.
It's either a power problem or a transmission switch fault - the transmission switch changes resistance depending on what gear you are in (see the depiction)
137163
You can test the switch with an ohm meter connected to the two pins on the switch. If the switch is fine, then it could be the ECM or the display - take it to a dealer to run the diagnostics.
Thank you for the help I will look at the transmission switch and see if anything is going on there
Agreed ohm out the switch. But first look over the wiring to make sure there are no obvious signs of damage.
