'09RZR,'17Sportsman450HO
Hi, newbie here so bear with me...
I'm looking to replace the brake pads on 450HO which isn't a problem finding an aftermarket set for the front (EBC); However, I realized that the rear (RH side of course) is different then the front set. Problem is I can't find an EBC part number for the rear set.
Any suggestions would be appreciated. Thanks in advance.
there FA475R.
anytime bud!!
bp I was just looking at EBC FA475R
pads online. I checked at least 5 different places and because the ‘17 450 and 570 use same, I checked “Fitment” on each site and all said incorrect fitment. I know their “Fitment” charts can be incorrect often. It does say correct for an 800.
Just cross referenced the 800 to 450/570 and YOU are correct, they use same pad. Like I said their Fitment charts are often incorrect! Think of the sales losses.
Oh man reading the post thought I messed up. You're right though the charts across the board get it wrong to often!!
Reactions: Sprotsman
All good boys! I installed the new pads as suggested above, fit great. Thanks again
