I have replaced 3 one way bearings in the past 3 weeks, i inspected it some more and it seems that the belt is crooked on the clutch on the transmission. I really need some help with this any thing will help. Thanks.
so your belt is out of alignment and the cause of your issues. what caused the mis alignment is the question?? it could be a mount (motor or tranny) is bad and caused a shift to either. so I would inspect the mounts and make sure none of the mounting bolts loosened up.
