Hey guys need help I drove my sportsman today for like an hour did great no noises at all shut it off to help push a friend out of mud .I went to start bike back up and wouldn't go anywhere towed it back took belt box off primary clutch just free spins while running or not .My linkage is working as it should but the primary will not spin at all with motor u can free spin it with ur hand very easily plz help hope some one on here can relate
Sorry i am not familiar with the late models but it sounds like your going to need to strip down the primary somethings failed on the main shaft maybe a keyway or spline one way clutch did you notice any lose of engine braking when your off the gas
i am sure someone with more knowledge will be a long soon hang in there.
There were 41 Sportsman models - which one do you have?
My guess is the primary clutch is loose on the crankshaft - remove it, clean the crankshaft and the inside bore of the clutch, install and torque.
