Hey guys, do you need to remove the engine to replace a head gasket on the Scrambler 1000? The service manual mentions that the cylinder head is accessible by removing the upper right-hand frame support.
I'm away from my ATV right now so I can't check to look for a couple of weeks.
Thanks!
ACCESSIBLE ENGINE COMPONENTS
Components serviceable with engine installed:
• Flywheel
• Alternator (Stator)
• Starter Motor / Solenoid
• Cylinder Head / Valves
• Camshaft / Camshaft Carrier
• Rocker Arms
• Water Pump
TOP-END SERVICE (ENGINE IN CHASSIS)
The top-end of the engine can be serviced while the
engine is mounted in the chassis. A removable upper
right-hand frame support allows access to the valve
cover and cylinder head.
Thanks!
• Flywheel
• Rocker Arms
• Water Pump
