I purchased a 2018 Sportsman 570 (see picture) with a damaged Display connector. I don't want to have to purchase a whole new harness for $800-$900. I am wondering if anyone knows where I can get this connector or maybe if this same plug is on another model that I can get it cheaper from. I was looking at some used wiring harness's and it looked like a 2015 Ranger 900 XP might have a similar plug. I am ok with splicing in a new plug, I just need one in better condition than I have. Thanks for any help
Here's a list of machines with the same harness. There are several variations according to model style so I'd first find the ID tag on your harness with the part number to make sure its compatible. I'd think they all would have the same connector for the display though. There's several used ones on ebay for around $60. I'd get one and just splice the connector into the harness you have and solder/wrap the splice.
2412885 Here's a link to the ebay search I did with this part number.
https://www.ebay.com/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=2412885&_sacat=0
Year
Product
Model
Assembly
2019
ATV
SPORTSMAN 570 EFI (R01)
ELECTRICAL, MAIN WIRE HARNESS - A19SEA57B1/5/9/L2/L7/E57B1/5/9/SEY57B5
2018
ATV
SPORTSMAN 570 EFI (R09)
ELECTRICAL, MAIN WIRE HARNESS - A18SEA57B1/7/9/L2/L5/L7/E57B1/B7/B9/BK
2017
ATV
SPORTSMAN 570 EFI (R16)
ELECTRICAL, MAIN WIRE HARNESS - A17SEA57A1/5/7/9/L7/L8/E57A1/7/9
2017
ATV
SPORTSMAN 570 EFI HD (R08)
ELECTRICAL, MAIN WIRE HARNESS - A17SEH57A7
2016
ATV
SPORTSMAN 570 EFI (R13)
ELECTRICAL, MAIN WIRE HARNESS - A16SEA57A1/3/7/8/9/L3/L7/L8/E57A1/3/5/7/9/D57A2
2016
ATV
SPORTSMAN 570 EFI HD (R11)
ELECTRICAL, MAIN WIRE HARNESS - A16SEH57A7
2015
ATV
HAWKEYE 325 2X4
ELECTRICAL, MAIN WIRE HARNESS - A15SAA32EH (49ATVHARNESS15SPETX)
2015
ATV
SPORTSMAN ETX EFI
ELECTRICAL, MAIN WIRE HARNESS - A15SEA32AA/AH (49ATVHARNESS15SPETX)
2015
ATV
SPORTSMAN ETX EFI MD
ELECTRICAL, MAIN WIRE HARNESS - A15SEA32HA (49ATVHARNESS15SPETX)
2015
ATV
SPORTSMAN 570 EFI
ELECTRICAL, MAIN WIRE HARNESS - A15SEA57AA/AC/AD/LD (100034)
2015
ATV
SPORTSMAN 570 EFI EPS
ELECTRICAL, MAIN WIRE HARNESS - A15SEE57AA/AC/AJ (49ATVHARNESS1570EPS)
2015
ATV
SPORTSMAN 570 HD
ELECTRICAL, MAIN WIRE HARNESS - A15SEH57AD (49ATVHARNESS1570EPS)
Thanks for the response. I did a little more research and found a part number for the grey housing. From there I found this. https://www.eficonnection.com/home/product/delphi-16-way-medium-gray-micro-pack-100w-sealed-female-connector
Let me know if you think this will work?
Thanks.
Well, that certainly LOOKS like it. If you're comfortable enough to insert your own pins and make sure they are in the correct position then that may be the way to go.
Whatever route you choose make sure to let us know and post some pics.
I will get you update as soon as it’s done. Any idea what gauge wire is usually used on those? That website gives me two options. Thanks for the help.
I'd go with the 18 ga sockets. 20-22 are too small. You'll need a special crimp tool though.
Can you not just release the sockets from the connector and reinsert them into the new connector body? I work with these types of connectors all the time.
Mark
I can for the most part. A couple of the sockets are broken or bent and will need to be replaced. Thanks for the gauge size. Just ordered what I hope will fix it.
