1 - 1 of 1 Posts
I am getting an error 168 3 over voltage reading on my 2018 570 Sportsman, I replaced the Voltage regulator and have checked all wiring for shorts and loose connections, I even ran stator wires in the same plastic wire protector as the rest of the wiring so it couldn't short to anything. I have have also swapped the battery with same symptoms. My concern is that even disconnecting the battery, the code remains without starting the machine. I believe there is or must be a way to reset the code internally because it doesn't appear disconnecting battery clears it.
1 - 1 of 1 Posts
