· Registered
So ive been having problems with my 2018 sportsman 570 running rough and starting hard so i replaced the fuel pump as many said would be the problem. That didnt make a difference it still seemed boggy on top end as it did before. About a week ago it quit running all together so i replaced the injector and still wont start. Fuel pump is running as it should, good fuel pressure. got spark, good compression. If I take the throttle bodie off it will start and run. I took mass air flow sensor out checked it and air temp plunger deal appears to be working as it should.I just ordered a tps sensor today but im not confident that is the problem. Called every dealer in the area and they are booked out for a month. We use it on the farm everyday so i have to try and get it fixed. Any suggestions?
· Registered
Should have got a model with a carburetor - EFI is over rated.
I had a 2017 carburated 300. Great ATV. But hated the carb when it was -20c
Couldn't keep it running unless it sat with open choke for a min if 5 min. Even then sometimes I had to give it throttle.
Any EFI I've had starts right up. Never an issue. Still need to warm up the engine and belt though.
I dont think I would be hesitant to have a carb again either though.
Sent from my SM-A715W using Tapatalk
· Registered
2014 Sportsman 570
Did you figure out the issue? What was the cause?
