2018 Polaris Sportsman 850
New 2018 850. 100 miles on it. Been on 2 rides Most miles have been put on it just riding the kids around the yard. It has not been hurt. Run hot on a ride months ago and cooled to normal with the fan. Washed everything out good when I got home. Have used it since with no lights on as well as the fan running like its supposed to. Cranked it a week ago and the over heat light came on and wont go off.Rode it to get the temp up and the fan came on at 196 and cooled it down then cut off. The light is still on. Then this weekend the turtle light came on and it wont go off. Ive tried getting a code from the display but it doesnt show anything. Ive unhooked the battery for minutes, hours and then over night. The lights are still on. Ive read the manual, googled, youtube'd and now Im here.
The local Polaris shop is backed up 3 months before they can even look at it.
Anyone got any ideas ?
I have the same bike and mine did that too around 100 miles, I had only ridden about 5 miles when that happened to me. I turned the bike off, let it cool down, took the rad cap off and found that it had air in the system. I let it idle for 10 minutes with the cap off, bubble came up and now have a about 1200 miles on it and not 1 more problem.
so elevate the front remove the rad cap. burb the system and add coolant. remove the battery cables let it sit for 30 min and re-connect. should be good to go!!
Thank you so much. Going home to try this now!
