1 - 14 of 14 Posts
Has anyone added the work light in the 3rd brake light location? Is it wired already. Parts needed etc.
Yes, The wire is in the pod and all the way back to the rear. Buy the light and switch....Plug and Play.....
The plug in the back is zip tied to the rear frame. Remove the rear rack and you will see it.
Yes I put one in on my 850SP.
Very straight forward. Under the headlight pod is a yellow wire, that is your power wire for the switch. Under the rack is the plug, as FPD stated, it is zip tied to the frame. Plug that into your light and your good to go.
I opted for the tail/brake light combo. I then mount 2 white LED work lights under the OEM tail lights.
Does anyone have the part number to get the 3rd light in red and not the white work light?
I posted it above.....
Look at post #3 its listed on the bottom of the picture........
No Problem. Got mine from ebay, very easy install.
I went to an art and craft supply store and bought a fine point paint pen in that color
1 - 14 of 14 Posts
