I got a sportsman with a blown front diff and a 520207 "4" code. Replaced diff with a confirmed working unit.
Code remains. The plug at the front diff remains energized no matter where the switch is. The AWD is stuck on unless i disconnect the plug at the front diff, then its 2wd. At no point do i ever see a AWD indicator on the dash.
There is a host of wiring splices from heated grips, lights etc that I'm working through.
Can anyone recommend any test i can do with a multimeter? Fuses? Chassis relay? At this point i just want to understand it and narrow it down. Thank you.
