It was negative the last few nights and it's 10F today. Went to start the wheeler to move it into the garage (where it belongs in the safety and comfort of my heated garage), only received a loud click/clunk when turning the key. It sounded like the starter was frozen (dunno if that's possible/reasonable to suggest). The dash was working fine, the front headlight was strong, the rear brake lights were strong. The voltage on the dash indicated 11.5v which is lower than normal but the weather would explain the drop.
I have an SAE connector rigged to my stock battery which I sometimes use for my light bar (there's a rocker switch and fuse inline, don't worry). I also have my Vexilar rigged with an SAE connector which I can use for charging, LED lights, or other accessories while fishing. The benefit is that I can connect my Vexilar (12v 10ah LiFePo) to my wheeler for battery assist if needed. Well, I tried that. It bumped the voltage from 11.5 to 11.9 but sadly still would not start the wheeler. I connected my CTek charger which has a 12v 7amp "supply" setting but still got the same clunk result. It almost killed me but I was able to push the wheeler into my garage. After sitting for about 10 minutes in the now warm-ish garage, I tried again and it sluggishly started. Yesterday, which was even colder than today, it started right up and I rode it for a little while on the nearby lake. I'm assuming the lower than normal voltage (combined with the extreme cold) is to blame for the failure to start.
GOAL: I'd like to replace the battery with something that I don't have to worry about when I'm out on the ice. I'm not super worried about the cost. I want something heavy duty, reliable, plenty of juice to turn this pig over AND will tolerate the cold Minnesota winter temperatures. I don't always park it in the garage but I do have access to a nearby power outlet when it's parked outside for a tender/trickle if needed.
So far I looked at the Antigravity website. The battery "finder" page doesn't include my year Sportsman. Decided I would consult the fine experts here. I searched the forum briefly but didn't see anything specific to my situation. Forgive me if this topic has already been covered.
QUESTION: Anyone have experience and/or recommendations to share? Please provide specifics, model #, links, etc. if you can. Thanks in advance!
