Yep, you're friendly Polaris dealer for $90. I think they are printed when ordered and take a couple weeks to get for the new machines.In search of a service manual for a 2019 Sportsman 850 SP. Anyone have a source where I could obtain one?
Thanks,
Is this still available?I have a 2018 850/1000 manual - Polaris publication 9928503 - in PDF - it should cover most of the 2019 model PM me your email address and I'll send it to you.
Sent you a PM for your email addressIs this still available?
Could u possibly send it to me my email address isSent you a PM for your email address
Don't have the 19 revision - sent the 2018 publication 9928503 which is updated to 9930994 - the new version covers 2018 thru 2020 - the only difference is the older manual does not have the specs published which are virtually the same except for minor differences - I will get the 2020 revision and replace the 2018 version, but it takes quite a while to convert the hard copy to PDF.Could u possibly send it to me my email address is
[email protected]
I dont see it in my emailDon't have the 19 revision - sent the 2018 publication 9928503 which is updated to 9930994 - the new version covers 2018 thru 2020 - the only difference is the older manual does not have the specs published which are virtually the same except for minor differences - I will get the 2020 revision and replace the 2018 version, but it takes quite a while to convert the hard copy to PDF.
Thank youEmail travels at the speed of light, but it is slowed down in Cyber Space - you should get it shortly
When I bought my new machine the parts guy told me the hard copy manuals are only printed as ordered. I don't know if I actually believe that but it took a couple or three weeks to get mine.So you ordered the manual from Polaris and are waiting on it? According to my sources, it is available now @ $78 dealer cost and $90 retail
OK - that is true - if you order it from a dealer; they can input the part number and order a hard copy which is printed and shipped (about 3 weeks) - if you buy it direct from Polaris and bypass the dealer, they will provide you with a PDF copy and it's basically instant download - not all manuals are available in PDF.When I bought my new machine the parts guy told me the hard copy manuals are only printed as ordered. I don't know if I actually believe that but it took a couple or three weeks to get mine.
Hey, do you mind sharing a copy of service manual? I have a 2019 sportsman 850 highlifter with a big hole in the block... Can you email it to me at [email protected] or whatever method is easiest for you?I have a 2018 850/1000 manual - Polaris publication 9928503 - in PDF - it should cover most of the 2019 model PM me your email address and I'll send it to you.
