Wait what??? Why just the clutch housing????? If any thing I would snorkel the engine intake first!!!! Chk Highlifter or wild boar.
I'm the same way the clutch in and out is very low at about the top of the tires and the engine air box inlet is right below the handlebars.I too been looking for a small upgrade.
The clutch intake is that low????? The exhaust isn't as important unless you shut the machine down and if you do that in deep water you have bigger problems!!!
You ever find anything OP? I've sorta thought about trying to get the belt ducting up a little higher. I don't do much water but have to sometimes to get where I wan to go. The OEM clutch ducts are uncomfortably low for me too.
Wrong,.. on the 850 if you're ass down front up water will get in through the rear cvt exhaust if you stall or revs are low,.. it's a really stupid place. I snorkled my CVT, then removed it and put on a 2009 850 CVT exhaust that goes up under the seat by the air filter.
