1 - 17 of 17 Posts
Hi everyone I have a question I put outlaws tires on my 2020 polaris 450 and noticed that the left side tie rod was rubbing on the tire but had space on the right side do you think its a ball joint or something else and I put 2 inch spacers
Welcome to the forum
What size tires did you install?
2004 Sportsman 700, 2004 Scrambler 500, Various Others.
Did you keep the stock rims or changed the wheels and tires?
I put new wheels and tires 14 rims and 29.5 outlaw 2 but it is only cambered on one side the tie rod hits the tire and the other side has 2 inches before it hits the tire
Pics???
Jack it up and start investigating!!
Something sounds bent, worn, or both!!
Ball joint has noting to do with this.
TRE bolts direct to strut.
Wheel bolts to hub to which sits in wheel bearing and retained by axle.
Severe bearing play can cause wheel to lean.
What wheel are you using?
Discussion Starter · #15 ·
Polaris high lifter 14
If you don’t see anything put other wheels back on if you have them, remove spacers, and take a look. That should rule out any front end part if it was fine before you swapped wheels! On a side note, any rubbing on the rears?
1 - 17 of 17 Posts
