1 - 2 of 2 Posts
Does anyone have any idea how to bypass the brake and throttle safety my brand new 2020 scrambler 1000s goes into limp mode if I tap the brake while throttle is engaged check engine light will come for a second then clear and it will run fine till it does it again I rode sun and the dealer said it came on 86 times lol I need a bypass or reflash any info would help
I don't think my 2018 Sportsman XP 1000 does that because I do very steep rock crawling and you got to use the throttle before can let go of the brakes and the throttle doesn't have a safety switch but the brake handle does so all you need to do is put a switch on it so that you can turn it on to start it then off when riding. The brake light works a pressure switch.
1 - 2 of 2 Posts
