2021 850 highlifter
1429 Views 9 Replies 7 Participants Last post by  WhiskeyThrottleScubaSteve
What mods can I do to get more speed
1 - 10 of 10 Posts
to the forum
See less See more
2
You will need to change the gearing in the transmission
  • Haha
Reactions: 1
Go to RVSPerformance and get it un-corked!!
Get a 1000
Buy a sportsman
Sent from my SM-G970U using Tapatalk
Reactions: 1
Are you running stock high lifter 29.5” tires ?
If yes, you can open up the clutch box and remove the plastic limiter in there and gain a few more mph. You’ll also need to consult with Ryan, from RVS and get your ecu tuned. If you have high lifter model, the most you can go I believe is the stage 2 with a after market exhaust
Any more info on that clutch mod? Never heard of that before
Sent from my SM-G991U using Tapatalk
So tbh, I’ve never had to do this procedure before. But I spoke to Ryan on doing clutch kits on my bike and he said there is a little plastic clip somewhere in there that can easily be removed and you can gain a few more mph without it. From what I understand, it prevents the belt from going up to its full potential on the spindle of the clutch. All you have to do is call RVS, speak with Katie or Ryan and they’ll tell you all about it. I still need to order a new helux and clutch kit 😬
Rectangle Font Schematic Parallel Building
Product Gesture Font Screenshot Parallel
See less See more
2
  • Wow
Reactions: 3
1 - 10 of 10 Posts
