Will 29.5x9.5x14 OL2 fit on a stock 14" rim? I have a 2016 Sportsman 850 SP. In the process of installing a CATVOS 3" lift
You might be a little close to your rear sway bar. I have 28" (measure close to 29) terms on my stock rims, but they are 12" wide in rear and as you can see I am close, I will probably just remove the sway bar, or most likely I will get aftermarket rims as I want to be able to swap these back n forth to the rzr...
Edit: Plus your 3" lift will maybe suck the tires in a bit, so you may want to go to an after market rim anyway..
They will fit fine, If your not dead set on OL2s I would look at other options.
