1 - 1 of 1 Posts
All right... To set this up.... the 300 was running pretty well on the last trip until she started to bog down. I had to push her back with my Foreman because it couldn't even go up hill.
Now I have it back in the garage and I can't even get it started again.
1. I have charged the battery so there is enough voltage
2. There was a weak spark when I pulled the cord (Starter motor is shot so I have to pull start it) then I checked the plug wire and the ignition coil and I no longer have a spark.
3. There is fuel getting to the spark plug because the plug it wet everytime I pull it out.
Do you guys have anything I could check out on this pig?
Oh, and it is the 95' polaris 300 2x4.
1 - 1 of 1 Posts
