My wife's 300 Xpress was very hard to start. You had to crank it for several minutes and it would finally fire. I pulled the cylinder and had it bored and new piston and rings. Compression is great. It started and then is doing the same damn thing. I found the spark plug bad. It is still hard to start. The oil is injected directly into the carb from what I see, What I think was that the plug was bad and the carb was getting pumped with oil. After it starts and you shut it down, it starts fine until it sits. Any ideas?
Dewey
Dewey
